gas exhaust smell
PLYMOUTH
PAMILYAS
I have a 1986 Plymouth Caravelle with a 4-2.2L engine and 80,200 miles on it. When I start the car and turn on the heat or A/C there is a faint smell of gas or exhaust inside the car. I had a mechanic look for the problem and they said the fuel line needed to be replaced. I had the line replaced and I can still smell the gas/exhaust through the vents when the heat or A/C is on. The smell goes away if I turn the blower off. What could be the cause of this?
Feb 15, 2007 at 9:59 AM
2CARPRO JACK
  • 11,533 POSTS
Any exhaust leaks? (ticking sounds) Try the recirculate button or max A/C and see if the odor goes away.On regular the system sucks air from the base of the windshield, there might be some other leaks. Could also be some contamination in the vents, try turning on your heater and spray a little Ozium at the base of the windshield, let the car air out a little and see if it goes away
Feb 15, 2007 at 10:36 AM
PAMILYAS
When the vent is on max the smell is stronger. I will try the ozium spray.
Feb 15, 2007 at 1:20 PM
MALLETSLINGER
  • 19 POSTS
If that wasn't the problem...
Another possible cause could be that something is leaking onto(or was spilled on) the exhaust manifold.
The substance being burned on the exhaust manifold could be Oil, grease, transmission fluid, power steering fluid, or break fluid.
Look around when the car is cool, and if you find something, clean it up with some paper towls or a pressure washer, but be careful not to get any electrical components wet under the hood.
Feb 18, 2007 at 2:17 AM
TESTA
That is not going to help!! I have a 93' Plymouth same problem!! I have tried everything!!
Feb 20, 2007 at 6:24 PM
2CARPRO JACK
  • 11,533 POSTS
MAybe time to drop the fuel tank and check the seal on the sending unit
Feb 20, 2007 at 7:08 PM
MALLETSLINGER
  • 19 POSTS
Have you checked the charcoal canister yet? It could be the culprit.
Or maybe an vac. hose.
Is there anything else wrong with the car like stalling, hard starts, overheating, or decreased fuel economy?
Feb 20, 2007 at 10:52 PM
TESTA
Yes, I have stalling, and it seems to be missing as well.
Feb 21, 2007 at 9:00 PM
MALLETSLINGER
  • 19 POSTS
Well if you are shure that there are no fuel leaks in the engine compartment (like at the fuel filter, or loose fuel injectors) then I would start by:
Checking/replacing: spark plugs, plug wires, air filter, distributor cap and rotor
Replace the fuel filter if you haven't done it recently.
Add some good fuel system cleaner to your next tank of gas.
All of these things are considered normal maintenance, and they could solve your problem.
Feb 22, 2007 at 2:49 AM
