2001 Other Plymouth Models Car won't shut off at times
2001 PLYMOUTH
ANGELDEVINE83
I've been having problems with the car not wanting to shut off when I turn the key in the ignition. It wouldn't do it all the time but the key would come out and move back in forth and still the car would not turn off. Finally after about 20 trys with moving the key around it would. I changed the ignition switch 2's and it worked fine and now its doing it again. I haven't replaced the tumbler in it and that might be the problem. Do you have any ideas on what could be causing this? I keep replacing the switch but that is now starting to add up.
I need some help
Oct 29, 2008 at 10:56 AM
The tumbler could be the problem, or the new switch may have gotten loose and need adjusted. If you turn the key to ACC, does it turn off?
Mar 22, 2009 at 3:56 PM
