1999 Other Plymouth Models Spark Plugs
1999 PLYMOUTH
152,000 MILES • 4 CYL • FWD • AUTOMATIC
SASS333
Replaced water pump, car has been backfiring and losing power since, checked spark plugs and all 4 have oil on them, any idea what could be wrong? :S
Jun 3, 2008 at 9:31 PM
MMPRINCE4000
  • 8,548 POSTS
Check all electrical connections and look at the areas you were in when changing the WP. Make sure the PCV valve is working.
If you have any codes, scan the PCM. Sometimes when working on a car you can inadvertantly break a vaccum line or pinch a spark plug wire etc.
Carefully go over the car, again checking items you disconnected or touched when changing the WP.
Jun 4, 2008 at 4:43 AM
