1998 Other Plymouth Models Car won't fire
1998 PLYMOUTH
PROHRBACH
  • 4 POSTS
Engine Performance problem
1998 Other Plymouth Models 4 cyl Two Wheel Drive Automatic
Car won't fire but has spark...Pulled off fuel line at pump and cranked car NO fuel. Fuel Pump or main computer?
Nov 28, 2008 at 1:48 PM
Do you hear the fuel pump when you turn key to run-if so do a fuel pressure test-if not start with the fuel pump fuse and relay-sounds like the fuel pump
Nov 28, 2008 at 1:54 PM
PROHRBACH
  • 4 POSTS
Fuel pump fuse all good and relay good no pressure in ejector or lines
Nov 28, 2008 at 1:58 PM
Replace the fuel pump
Nov 28, 2008 at 2:00 PM
PROHRBACH
  • 4 POSTS
New fuel pump put in....went form having no fuel into ejectors to now having fuel in ejectors with new pump but car cranks but won't start HELP!!
Nov 29, 2008 at 7:08 PM
What you need to do now -is check for injection pulses-listen to the injector/s while cranking engine over -do you hear it clicking, also you can use a noiid lite for this test.
Nov 29, 2008 at 7:22 PM
PROHRBACH
  • 4 POSTS
I poured a little bit of gas down the throttle body and still no fire
Nov 29, 2008 at 8:47 PM
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark?
Nov 30, 2008 at 7:21 PM
APRILSTARMOON
Hey i have a similar problem...car will turn over but wont fire. what did you figure out with your car?
Dec 28, 2008 at 7:30 PM
