1997 Other Plymouth Models Engine turns over but doesn't sta
1997 PLYMOUTH
172,000 MILES • 4 CYL • FWD • MANUAL
MATERMANIAC
I have a '97 Plymouth Highline 2.0L DOHC 5-spd. I was driving to work when my car died. This has happened before. I changed the fuse (underhood fuel pump) and it blew again (and again and again). Well the computer had been telling me the egr solenoid voltage was too high/low. I changed the egr (solenoid comes with). After that I tried to start. No dice. Checked timing and was fine. Tried to start. Nothing doing. Changed spark plugs. Checked the resistance of coil pack and plug wires by book. Falls within specs. Changed computer/ECM/PCM. Still won't start. I don't get any spark at plugs and I don't think the fuel injecters are working either. HELP!
Sep 9, 2008 at 9:23 PM
Hi:
Have you checked the fuel pump relay? Also, if the fuel pump is blowing fuses, either the pump has shorted or the power supply has.
Oct 13, 2008 at 10:38 AM
