1997 Other Plymouth Models
1997 PLYMOUTH
YOUNG_EASY
Transmission problem
1997 Other Plymouth Models 4 cyl Front Wheel Drive Automatic
When i am driving and let off the accelerator the transmission slips into neutral and the engine revs and it slams into gear hard Can you please help me
Apr 4, 2008 at 8:04 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds low on fluid. Warm the car up, with it on level ground. With it running remove the trans dipstick and wipe clean. Should say on the stick if it needs to be in Park or Neutral when checking fluid.Insert and remove dipstick and check level, add as needed
Apr 5, 2008 at 8:29 AM
