1996 Other Plymouth Models ENGINE STOPS WHEN IN MOTION
1996 PLYMOUTH
15,000 MILES • 4 CYL • 2WD • AUTOMATIC
TORMAN
I am using a Plymouth neon 1996,i have used it for
three years now;just recently i notice that when drive ,the engine stops ,and start again,i was ask to change my fuel filter and pump.which i did;again the engine still goes off; now when you start start the engine it will not
start,i was ask to check the engine control module,and change it.now the engine still goes off.
when the car is moving the engine stopped.
Oct 12, 2008 at 8:54 AM
Hi:
Have the computer scanned for codes so you don't spend all your money on items you don't need. Once you get the code, you'll know what to replace. If you run into trouble, let me know.
Oct 13, 2008 at 10:19 AM
