1995 Other Plymouth Models Car will not start no matter what
1995 PLYMOUTH
99,000 MILES • 4 CYL • FWD • AUTOMATIC
MIKEKENYON
My 95 Plymouth neon stalled on my way home one day and wouldnt start up. I got it towed to a shop and they have now had it for a month and it still won't start. They replaced the tank and fuel pump and fuel filter. They tried a new throttle position sensor, distributer, throttle body, crank sensors, and replaced the plugs like 4 times. They have great compression, great fuel pressure, and good spark. The timing is perfect also. I also replaced the plugs and wires two weeks before it died. THE DAMN THING STILL WON'T START!!!!! I am going to be stuck paying for all this trouble shooting also. Is there anything you can think of that i can suggest to them to get it out of their shop and back in my driveway running? (I would like to add that the shop is the best within 20 miles and they would not bullshit me to run up the cost)
Apr 14, 2008 at 5:56 PM
ZATABALA
I have a 95 neon with the same problem. Did you get a answer to your problem yet. I can't figure out whats wrong. I put a new starter and battery in but nothing.
contact me at [email protected]
Apr 23, 2008 at 2:18 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:753c45850f="mikekenyon"]Engine Performance problem
1995 Other Plymouth Models 4 cyl Front Wheel Drive Automatic 99,000 miles
My 95 Plymouth neon stalled on my way home one day and wouldnt start up. I got it towed to a shop and they have now had it for a month and it still won't start. They replaced the tank and fuel pump and fuel filter. They tried a new throttle position sensor, distributer, throttle body, crank sensors, and replaced the plugs like 4 times. They have great compression, great fuel pressure, and good spark. The timing is perfect also. I also replaced the plugs and wires two weeks before it died. THE DAMN THING STILL WON'T START!!!!! I am going to be stuck paying for all this trouble shooting also. Is there anything you can think of that i can suggest to them to get it out of their shop and back in my driveway running? (I would like to add that the shop is the best within 20 miles and they would not bullshit me to run up the cost)[/quote:753c45850f]
What codes are they getting? Does it Turn Over (Spin)? Does it have a Knock Sensor?
May 11, 2008 at 11:22 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:0fa005c73e="zatabala"]I have a 95 neon with the same problem. Did you get a answer to your problem yet. I can't figure out whats wrong. I put a new starter and battery in but nothing.
contact me at [email protected][/quote:0fa005c73e]
I take your car wont turn over?!
Have you checked all your battery wires especially your ground. A bad ground will cause the problem, check the battery negative wire make sure the ends are clean, if not sure remove them and clean them up good. Also check to see if it has a starter relay it should be in the fuse block under the hood.
May 11, 2008 at 11:30 AM
