I have a 1994 Plymouth Grand Voyger [6cylinder] with heating problems.I replaced the thermostat and top radiator hose and backflush the system but still had little heat.The heater hoses are hot and so is the radiatorhose.So i figured that air was trapped in the systembut no bleeders are installed.I took out the temp.sending unit and made my own bleeder and it worked,I got heat.But whe I take the van out for a test drive I LOOSE HEAT.All hoses are still hot.So i bleed it again and still have the same problem ,over and over again.What else can I DO.This has me stumped.Could there be another problem that causing this to happen
Jan 31, 2010 at 8:24 PM
