My daughters 1993 Sundance has a problem when started it idles very rough.When put into drive or reverse its even worse! Hardly any power.
I checked the code using key method and it gave a 35 error which is cooling fan relay circuit open or shorted. Also gave a 55 which is end of code.
I put a new fuel pressure reg. on it because it was leaking,also a new fuel filter. I also noticed a leak from the bottom hole that is on top of carburetor. Not sure what it is called. The bottom hole looks like it is plugged for some reason and a small crack developed,but last I checked it is not leaking now.
Not sure we don't drive it now. Any help appreciated
Jul 9, 2008 at 1:02 PM
