1960 Other Plymouth Models positive ground
1960 PLYMOUTH
LUKEROSE13
Electrical problem
1960 Other Plymouth Models 6 cyl Two Wheel Drive Manual
the car is actually a 1946 plymouth special delux, and i need to find out it this a 6 volt positive ground system
May 6, 2009 at 11:31 AM
HMAC300
  • 48,601 POSTS
if this is stock then it is probably a 6 volt system. If you look at your battery cables one cable end will be larger than the other. the larger end cable is a positive cable. If that goes to ground then it might be a positive ground.Be very careful though when hooking up a battery, if it is hooked up wrong it will spark badly. You could always contact the plymouth club or chrysler club in your area to find out about the positive/negative ground.
Oct 1, 2009 at 3:31 PM
