My Neon had the power steering /air condition belt break,we replaced the belt and the air and steering worked for just a moment and then the belt came off and did not break,it will not stay on and when I took it for repair and have called about having it fixed I am getting several scenerios. What could cause this to do this,what is the problem.I am being told it is the pulley that is a fairly inexpensive part and then I am being told it is the tensioner assembly,which is costly,a lot of work,and apparently needs done in a dealership. Currently the car is with no power steering or air conditioning,what could be causing these problems,could it be an easy fix,Any suggestions.
Sep 14, 2010 at 8:09 PM
