Engine Cooling problem
1998 Plymouth Neon Manual 75000 miles
the temp gauge is peaking several times over and then will drop to normal for a while then do it agian. we have changed the thermostat and it is still doing this. We have pulled the casing to check the belts thinking maybe it was the water pump but belts are fine. It will do this shortly after starting in neg. degree weather even.
We think it has something to do with the reserve.... please help with ideas of what to do next
Feb 23, 2009 at 4:27 PM
