1998 Plymouth Neon Noises from Clutch Area
1998 PLYMOUTH NEON
178,000 MILES • 4 CYL • FWD • MANUAL
JANDKY
There are noises coming from the clutch area on my wife's 1998 Neon. The clutch still works but it sounds like it needs to be tightened. How do I go about tightening a clutch on a 1998 Plymouth Neon. My experience level is that I can use the tools but don't all the parts of the vehicle.
Jan 26, 2009 at 2:56 PM
DOCFIXIT
  • 18,828 POSTS
It is a hydraulic system no adj. Is noise there only when pedal depressed?
Jan 26, 2009 at 4:11 PM
JANDKY
No not when the pedal is depressed, however when starting off in first gear the noise is present. Please be advised that this is a 5 speed manual transmission. Is there any fluid that I should probably check.
Jan 26, 2009 at 5:56 PM
DOCFIXIT
  • 18,828 POSTS
Check fluid fill plug on side trans just above drivers side axle. Is noise only there in 1st.
Jan 28, 2009 at 2:50 PM
