Engine Mechanical problem
1998 Plymouth Neon 4 cyl Front Wheel Drive Automatic
Car will start fine then about a mile down the raod the engine starts to miss or just die. It does not spit and sputter it looses power and the rpm's drop and there is nothing when you press the gas pedal. If it dies completly it will start afte sitting a couple minutes. Had it in the Garage and they cahnged the Crank Sensor but it is stil dooing this.
Sep 20, 2009 at 12:39 PM
