If ur speedometer don't work then ur odometer (mileage counter) WON"T work, it needs the speedometer to work it. If the rest of ur gauges work & just the speedometer/odometer aren't then check the speedometer cable connections to the cluster & transmission to make sure it's not lose at either point. If both connections are tight then unfasten one end & check the cable inside of it at both ends, they should be square shaped at both ends when looking at it head-on. If the edges are rounded replace the inside cable.
IF ALL THE GAUGES WORK INTERMITTANTLY: take ur cluster panel off & use a magnifying glass to check the solder joints on the circuit side of each gauge for cracks. They probably need some re-soldering.
Feb 24, 2012 at 3:24 PM
