1997 Plymouth Neon Broken timing belt
1997 PLYMOUTH NEON
BRIANT99
Engine Mechanical problem
1997 Plymouth Neon 4 cyl Front Wheel Drive Automatic
I have a 1997 neon with a 2.0 ohc engine. It threw the timing belt and I need to know if this engine is an interference motor. If there is a good possibility that it has a bent valve, then I am not even going to bother fixing it. Thank you for any info.
Mar 25, 2009 at 6:12 PM
BLUELIGHTNIN6
  • 16,542 POSTS
The 2.0 Liter SOHC and DOHC engines used in the Neon are interference engines. If the timing belt broke while driving there is about a 6 in 10 chance a valve came in contact with the piston. The only way to know for sure is to replace the belt and perform a compression check to see if any valves are not sealing.
Thanks for using 2CarPros.com!
Mar 25, 2009 at 6:32 PM
BRIANT99
Thank you for the response, I appreciate the help.
Mar 25, 2009 at 7:33 PM
