1996 Plymouth Neon code p1899 park/neutral switch
1996 PLYMOUTH NEON
125,500 MILES • 4 CYL • FWD • MANUAL
TBN0420
I changed the switch and the check engine light is still on, how do I fix this?
Feb 25, 2010 at 9:52 PM
BLUELIGHTNIN6
  • 16,542 POSTS
if the siwtch has been replaced then you will need to delete the trouble codes with a diagnostic scanner. if the code does come back after that, check for faulty wiring to the switch
Feb 25, 2010 at 10:05 PM
