my car will run fine till it reaches normal operating temp on the heat gauge then it will start missing really bad and die out. i grew up around cars and working on cars so i know some but i have changed the thermostat because i think it is over heating and that is what is causing it to shut down. and where is the water pump located is it ran off the timing belt? thank you for reading and any help will be appreciated
Jul 24, 2010 at 6:50 PM
