1988 Plymouth Horizon installed new thermostat, engine now
1988 PLYMOUTH HORIZON
90,000 MILES • 4 CYL • FWD • AUTOMATIC
TIDENERGY
Two years ago, the bottom clamp failed and the engine coolant emptied out. Had it repaired with new thermostat. Let gas get too low in tank recently, had the fuel filter and system cleaned out. From then on found engine gauge redlines from cold start after 3-4 miles driving. Had thermostat again changed, but still does it. Each time it redlined, I shut the engine off and the top rad hose is cold. After 1-2 minutes, I restart it and the temperature gauge drops to normal range, where I can continue driving with no problem. The mechanic now thinks it may be the head gasket. I'm thinking it is an air pocket in the coolant system behind the thermostat. He did try bleeding off the ria from the rad, but didn't open the Allen bleed plug to drain the air off if that is the problem. Any ideas appreciated.
Mar 20, 2010 at 9:17 PM
LEGITIMATE007
  • 5,121 POSTS
have it pressure tested, that will determine if there is a bad gasket. how good is the water pump?
Mar 20, 2010 at 10:05 PM
TIDENERGY
Will suggest checking the cylinder pressure Monday morning. Haven't noticed a problem with the water pump, but will suggest that it be looked at too.
Thank you.
Mar 20, 2010 at 11:44 PM
LEGITIMATE007
  • 5,121 POSTS
you are quite welcome, keep me posted
Mar 21, 2010 at 8:39 AM
TIDENERGY
Looks like the head gasket. It is losing coolant with white exhaust. Chemical test done also.
Mar 24, 2010 at 12:42 PM
LEGITIMATE007
  • 5,121 POSTS
there you go, such a pricey job for a part that costs less than twenty bucks
Mar 24, 2010 at 2:06 PM
