1994 Plymouth Colt No spark
1994 PLYMOUTH COLT
180,000 MILES • 4 CYL • FWD • MANUAL
MIMIJEMI
Engine stopped running suddenly, luckily just when I was about to park in front of the building, so I had to push it only 20m. I tried to start engine couple of times, but no luck. Battery is good, gas tank full. It was sitting there for two days. Then I tried again. Engine started with no problem and I left it running. It was running not bad but not perfectly, kind of like low rpm, and with tendency to stop, which actually did after 5 min. All attempts to start it aging didn't work.
I changed plugs, distributor cap and plug cables. I removed all 4 plugs and connected one against car body, started cranking but no spark on plug. There was smell of gas coming from the engine (through open plug holes), so I suppose gas is coming to cylinders, but there is no spark to ignite.
What next should I checked and how. I am not mechanic but can do few basic things (even more if I have detailed instructions).
Thank you very much for your time and help.
Mimi
Sep 1, 2008 at 9:01 PM
BMRFIXIT
  • 19,053 POSTS
remove distributor cap crank engine check if the rotor is turning
check timing belt
Sep 1, 2008 at 9:12 PM
