1991 Plymouth Colt Timing
1991 PLYMOUTH COLT
EVNCHYCODE103
  • 4 POSTS
Engine Performance problem
1991 Plymouth Colt 1.5L engine 4 cyl Front Wheel Drive Automatic n/a miles
Need a diagram showing where to set the timing and head bolt torque specs
Feb 7, 2009 at 8:43 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:82a9145fce="evnchycode103"]Engine Performance problem
1991 Plymouth Colt 4 cyl Front Wheel Drive Automatic n/a miles
Need a diagram showing where to set the timing and head bolt torque specs[/quote:82a9145fce]
Will need engine size in Liters for correct info.... it is either a 1.5L or a 1.6L.
Feb 7, 2009 at 8:59 PM
EVNCHYCODE103
  • 4 POSTS
[quote:f2a7ae14a9="obxautomedic"][quote:f2a7ae14a9="evnchycode103"]Engine Performance problem
Need a diagram showing where to set the timing and head bolt torque specs[/quote:f2a7ae14a9]
.[/quote:f2a7ae14a9] its a 1.5L sorry forgot to type it in.
Feb 7, 2009 at 9:10 PM
EVNCHYCODE103
  • 4 POSTS
Torque specs and a diagram for how to set timing belt would be greatly appreciated
Feb 7, 2009 at 9:21 PM
OBXAUTOMEDIC
  • 3,711 POSTS
I also added the timing tensioner adjustment...
https://www.2carpros.com/forum/automotive_pictures/188069_91colttimingmarks15L_1.jpg
https://www.2carpros.com/forum/automotive_pictures/188069_91colttimingtensionadjust15L_1.jpg
https://www.2carpros.com/forum/automotive_pictures/188069_91coltheadboltpatern15L_1.jpg
OBXAUTOMEDIC
  • 3,711 POSTS
Torq Specs - 53 Ft lbs in 2 -3 stages. Does not specify exact stages just as long as the last stage it 53 ft lbs.
Feb 7, 2009 at 9:27 PM
EVNCHYCODE103
  • 4 POSTS
thanks a lot that should do it.
Feb 7, 2009 at 9:33 PM
