wooring sound when accelerating
PLYMOUTH BREEZE
BREEZY WEEZY
I have a 1996 Plymouth Breeze 2.0L Automatic with 158800 miles. My question is this....it makes a wooring sound when it starts and gets louder as I accelerate. The car has been wrecked in the front end and repaired. I've had problems with power steering in the past but haven't had problems lately. I replaced the alternator thinking that was the problem, but it is still whining and seems to be a little louder now. Would the belt be causing this or maybe the air conditioning pulley? a friend mentioned bearings? As a female I have some knowledge in cars, but sure could use some help on this one! :?
Jun 3, 2007 at 1:48 PM
SERVICE WRITER
  • 9,123 POSTS
Could be wheel bearings, could be choppy tire wear, could be a pulley. IF the noise changes when turning one way or the other, i would suspect bearings. IF the noise is present when at idle and pitch changes as accelerator is pressed, I would suspect a pulley.
If you run your hand around the tread of the tires, it should be smooth, not choppy or sawtoothed etc.
Jun 3, 2007 at 6:51 PM
