Check Engine Light
PLYMOUTH BREEZE
TIAWRIGHT
I have 99 Plymouth Breeze and it has 144,000 on it. My check engine light came on. I went to autozone, got it tested and it was a gear 1 incorrect ratio. Do I need a transmission?
Sep 24, 2007 at 6:15 AM
SERVICE WRITER
  • 9,123 POSTS
You mean they checked the codes, what code number?
Sep 26, 2007 at 11:31 AM
TIAWRIGHT
[quote:40bf53cae0="Service Writer"]You mean they checked the codes, what code number?[/quote:40bf53cae0]
p0731, p0700
Sep 26, 2007 at 3:48 PM
SERVICE WRITER
  • 9,123 POSTS
PO700 "may" be a bad (EATX) Electrononic Automatic Transmission Controller.
PO731 is more complicated and is an intermittant problem. It is usually caused by intermittant hydraulic seal leakage in the clutch and or accumulator circuits.
After doing a little research, it seems that an input shaft speed sensor may solve the problem.
Sep 26, 2007 at 4:52 PM
