2000 Plymouth Breeze BRAKE LIGHTS NOT COMING ON
2000 PLYMOUTH BREEZE
XIER0
Brakes problem
2000 Plymouth Breeze 4 cyl
MY BRAKE LIGHTS ARE NOT COMING ON THE LIGHTS WORK BUT WHEN I HIT THE BRAKES THEY WON'T COME ON I DON'T KNOW THE REAL PROBLEM BUT I KNOW IT'S NOT THE FUSES AND I DON'T BELIEVE IT IS THE WIRING THOUGH I AM BY FAR NO EXPERT WITH CARS NOT BY A LONG SHOT I JUST BROUGHT A NEW BRAKE SWITCH BUT I AM AFRAID TO DO IT MYSELF I WANT TO SO IF IT IS THE BRAKE SWITCH HOW DO I REPLACE THE OLD W/THE NEW SAFELY
Oct 16, 2008 at 3:04 PM
ZACKMAN
  • 4,202 POSTS
Are you saying that both tail lights work, but when you step on the brake pedal, the brighter stop lights don't work? Including the third brake light on your trunk?
If all three lights don't come on, more than likely it is the stop light switch. If the third brake light (on the trunk) works, but not the two bigger ones, you need to replace your bulbs. If it was me, I would try new bulbs first (they only cost about $3) before I try installing the switch.
Let us know. If you need to replace the switch, I'll guide you through.
Oct 19, 2008 at 8:56 PM
