1999 Plymouth Breeze time to replace?
1999 PLYMOUTH BREEZE
165,000 MILES • 4 CYL • FWD • AUTOMATIC
NMCCLAI
I own a 1999 breeze with 165000+ miles. I need to replace water pump, timming belt, coolant sensor, cam shaft bearing, and engine leaks oil. Is the cost of these repairs worth it or is it time to look for a different car. Would it be possible to just rebuild the engine. I had not wanted to replace it for awhile if I can keep it running. Your opinion would be appreciated. Thanks.
Oct 11, 2010 at 10:22 AM
MERLIN2021
  • 17,250 POSTS
It would be better to look for a new car with less miles, if oil leaks, and cam bearings are needed, replace the engine or the car...
Oct 11, 2010 at 10:51 AM
