what would make the pcm fuse continue to blow?it jus started doin this,please hlp.this happens everytime we try and start car it blows fuse.
Apr 21, 2008 at 7:15 PM
BMRFIXIT
CERTIFIED EXPERT
are you able to crank the car when the fuse out
if no crank check the starter it may have to much draw
if its blow every time you turn ignition on and before it cranks look for a short
most likely its the starter
