1999 Plymouth Breeze Headlight bulb replacement
1999 PLYMOUTH BREEZE
143,000 MILES • 4 CYL • FWD • AUTOMATIC
MONICACB
Is there a certain way to extract and replace the headlight bulbs? It's a tight fit, even for a small hand, to twist the bulb, but after it loosens, I am unable to pull it out.
Also, there is condensation and dirt on the inside of the headlamp lenses, how do i remove the lense cover so I can clean it?
Your help is much appreciated.
~Monica
Jul 5, 2008 at 3:25 PM
MASTERTECHTIM
  • 4,750 POSTS
you cant clean the inside. you have to replace the light assembly if there is condensation inside. aftermarket parts such as headlight assemblys are very inexpensive now. unbolt the headlight assembly by the 10 mm bolts on top and it will slide out. get back to us if you need further help
Jul 5, 2008 at 5:20 PM
