1999 Plymouth Breeze engine dies at stop
1999 PLYMOUTH BREEZE
CARGUY779
Engine Performance problem
1999 Plymouth Breeze 4 cyl Front Wheel Drive 198000 miles
Engine tries to die when car comes to a stop, engine rpm drops and tries to recover. Engine is a 2.4L 4cyl. Thought of doing tune up and replacing TPS, then cleaning air intake system but dont know how to clean yet. Engine otherwise runs good with good power and timing belt has been replace.
Jan 19, 2010 at 6:12 PM
CARADIODOC
  • 34,308 POSTS
Was the battery recently replaced, disconnected, or run dead? If so, you need to do the minimum throttle relearn procedure.
caradiodoc
Jan 25, 2010 at 7:44 AM
