1999 Plymouth Breeze computer module
1999 PLYMOUTH BREEZE
20,000 MILES • 4 CYL • FWD • AUTOMATIC
JSIMMONS29920
i dont know if my speed sensor is bad where do i look and if thats my problem i have obtain a computer module but how to i replace it is there a special way
Oct 4, 2008 at 3:30 PM
ZACKMAN
  • 4,202 POSTS
If your speed sensors are bad, then your car is "stuck" on second gear, or "limp mode". If it is, the sensors are located on top of your transmission. You may have to remove the intake box and computer to see them. The sensors are of different sizes, I don't remember which one is which, but the connectors are of different colors.
When you say you have obtained a computer module, are you referring to Transmission Control Module (TCM) or Powertrain Control Module (PCM)? You may need a TCM, but not PCM. There is no special way to install it, you just need to make sure that the numbers on both TCMs are the same as they are non-interchangeable. They make 4 different TCMs from '95 - '00. 1 bolt holding the connector, and 4 screws holding the TCM in place.
Oct 11, 2008 at 12:10 AM
