1999 Plymouth Breeze Caliper rubbing inside of rim
1999 PLYMOUTH BREEZE
KAWIKA318
Brakes problem
1999 Plymouth Breeze 4 cyl Front Wheel Drive 102,00 miles
I have a 99 Plymouth breeze and the drivers side front caliper rubs the inside of the rim when I apply the brakes. All 4 rims are original. Is there something that wears out on the caliper that would cause it to rub on the rim? I know they float side to side to account for brake pad wear.
Dave
Oct 9, 2009 at 12:17 AM
Dave, if the wheels are OEM and the caliper is rubbing the wheel, the caliper has to be loose. Chances are you have a stripped retaining bolt.
Check that and let me know what you find.
Dec 20, 2009 at 1:37 AM
