No-code driveability and emission problems are the ones everybody hates,
One of the first things you should check is loop status. The fuel system cannot deliver the proper fuel mixture if is stuck in open loop. If the engine fails to go into closed loop after it has warmed up or been driven, it may have a faulty coolant sensor or an open thermostat. The next logical step would be to look at the coolant sensor's output to see if it is reading normally or if its resistance changes as the engine warms up. No change in resistance or a reading that is out of range would tell you the coolant sensor is bad. To check the thermostat, you could use an infrared thermometer to measure coolant temperature at the thermostat outlet after the engine has warmed up. If low, the thermostat may be open, missing or the wrong temperature rating for the engine.
You can also look at short-term and long-term fuel trim to see if the engine is running rich or lean. If the system is going into closed loop, look at the TPS and MAP inputs to make sure they are changing when the throttle position changes.
Nov 10, 2009 at 10:54 AM
