Engine does not turn over in park. when shift to Neutral and apply brakes, engine will turn over. Also there are no brake lights.
Dec 11, 2009 at 9:23 AM
JDL
CERTIFIED EXPERT
Welcome to the forum, Maybe an issue with tranes range sensor. You can use a testlite and check the voltage circuits at the starter relay circuits. As far as your brake lites, I'd check the voltage to and from the brake switch.
