1998 Plymouth Breeze Starting car
1998 PLYMOUTH BREEZE
135,000 MILES • 4 CYL • FWD • AUTOMATIC
KRYPTON
Engine does not turn over in park. when shift to Neutral and apply brakes, engine will turn over. Also there are no brake lights.
Dec 11, 2009 at 9:23 AM
JDL
  • 16,098 POSTS
Welcome to the forum, Maybe an issue with tranes range sensor. You can use a testlite and check the voltage circuits at the starter relay circuits. As far as your brake lites, I'd check the voltage to and from the brake switch.
Dec 11, 2009 at 1:43 PM
