1998 Plymouth Breeze no spark after changing ex manifold
1998 PLYMOUTH BREEZE
142,000 MILES • 4 CYL • FWD • AUTOMATIC
CSPRINGER826
  • 9 POSTS
well i had to change the ex manifold in my car so i went a got when and started the car up ran fine drove it on my ramps changed the manifold no there is no spark i have changed the coil, cranksensor un pluged the cam sensor still no spark checked all my fuses all my wires connections just cant figure it out now i have noticed that with the ingniton swith on the on position you can take the key out now i am woundering if that would cause it seeing i have just bought the car i dont no if the guy had riged the key up to work i am not sure????????please help me thanls
May 31, 2008 at 5:44 PM
2CARPRO JACK
  • 11,533 POSTS
Does it have spark? fuel pressure? need to see what is missing here. If has both get a noid light and check for injector pulse.If not, use test light to see if there is power at the coil
Jun 2, 2008 at 7:55 AM
