1998 Plymouth Breeze Battery loses power but Alternator is
1998 PLYMOUTH BREEZE
168,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOSHDAVIS1222
  • 4 POSTS
Hi there, I have a problem with my plymouth. Last night I blew out the starter motor which I changed this morning. After charging the battery back up I was able to start the car without any trouble. In fact, the car started fine throughout my entire pizza delivery shift, but I was noticing something a bit strange: after driving for about ten to fifteen minutes the battery light would come on in my dash... Taking care to pay attention to the warning signs such as the radio cutting on and off, the lights dimming, and general shutdown of the car, I didn't run into any of these problems. When I would return to the parking lot I did a quick check to see if the car would start again after I turned it off, it did, the battery light would flash on as it usually does upon ignition and it switched off after about three seconds. So I thought maybe it was a fluke and something just happened that corrected itself when I restarted my car. Wishful thinking, I know... So I made it through the shift, noticing this random battery light, each time happening around ten minutes into my delivery. So time came to go home. Before I left I checked the connections to make sure nothing had wriggled loose during my shift and, feeling satisfied with my findings I left and started home. On the way, about ten minutes into the drive, I noticed again, the battery light... But again, I didn't notice any loss of power to my systems, thinking the entire time, if its my alternator I would be losing power, optimistic, I know. So I continued to drive, worrying the entire time that I'd end up stranded, but I didn't. Finally I arrived home, turned the car off and took a deep breath turning the key back into the on position. Nothing...... not the sound of the radio not a friendly click of the ignition, not a ding reminding me that the car is alive, not a thing. So I'm thinking, awe man......what am I going to do now, still thankful that I was able to make it home.
So the problem is this. Car starts, runs fine for ten minutes or so, battery light comes on, runs on the alternator until powered down and then nothing. Any incites into this phenomenon would be greatly appreciated.
Nov 7, 2008 at 12:16 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Check your relays in the power distribution center and you should probably get that alternator tested just to make sure.
Nov 7, 2008 at 12:54 AM
JOSHDAVIS1222
  • 4 POSTS
just got done checking the alt. Its putting out 14 volts. I was finally able to crank the car only after removing the battery, which I had checked and was reading twelve volts, and putting it back in. The guy at the part store told me I should probably change my battery posts. I did. It was kind of strange because I put the new ones on and the car had the same issue as before, so I went in to see if I had tightened them all the way, gave the negative lead a good turn and got back in the car which started right up. I don't know, I'm trying to get ahold of a multimeter so I can check the continuity of the cables, but none of my mechanically inclined friends are answering their phones today. By the way, what do I look for when checking these relays?
Nov 7, 2008 at 10:46 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Check to ensure they are getting power to them.
Nov 7, 2008 at 11:13 AM
JNOVACK
  • 723 POSTS
aso have battery loed tested it may show 12 volts but it may have a bad cell
Nov 7, 2008 at 11:27 AM
JOSHDAVIS1222
  • 4 POSTS
Problem solved, randomly. Guess my battery leads weren't tightened enough. Thanks
Nov 7, 2008 at 8:22 PM
