Where to spray starter fluid in a 1997 plymouth breeze?
Thank you,
Hal
Aug 12, 2010 at 11:12 AM
BLUELIGHTNIN6
CERTIFIED EXPERT
your vehicle's engine is fuel injected and should not require starter fluid to start...it is a lot different and much more dangerous using starter fluid on a fuel injected vehicle than it is on the older carburator style engines..if you absolutely want to use it than spray it in the throttle body or as close as possible..
