1997 Plymouth Breeze oil in my spark plugs
1997 PLYMOUTH BREEZE
188,000 MILES • 4 CYL • FWD • MANUAL
CAMELW
I pulled out the four spark plugs and they all were covered in oil, the car seems to run good and there is no smoke coming out of the exhaust. What do you think the problem is?
Dec 8, 2008 at 12:55 PM
DAVE H
  • 13,384 POSTS
Problem & Possible Cause...........Action
Wet/Oil Fouled Plugs
Worn Rings/Pistons..........Overhaul/Replace Engine
Excessive Cylinder Wear.....Overhaul/Replace Engine
Dec 8, 2008 at 1:01 PM
PHATKID161
It happened to my 96 breeze buy a valve cover gasket kit autozone has it for 25 bucks what it is is the grommets for your spark plugs. I did it now they are fine
Jul 28, 2010 at 11:14 PM
