The problem is " engine stalls". Sometimes three times in the same day and other times, it is okay for a couples of days. The gas pressure is good. No code on the scanner. Plugs were change. The gas tank is full or empty it stalls anyway. Whether rains or sunny, does not make a difference. When the car stalls, you start it and it start right away. Do you have a solution?
Thank you
Thank you
May 5, 2008 at 8:01 PM
