Roll down window. If equipped with manual windows, remove window crank. Remove speaker grille from door panel. Remove screws attaching door panel-to-door from around speaker. Remove screw cap and screw attaching arm rest pull cup-to-support bracket. Remove screw cap and screw attaching door latch handle-to-door panel. Disengage clips attaching door panel-to-outer edges of door. Lift door panel upward to disengage upper retainer channel. Pull top of door panel away from door. Remove clip attaching latch linkage-to-door handle. Disconnect power mirror switch connector. Remove door panel. Remove screws attaching mirror switch-to-door panel. To install, reverse removal procedure.
Sep 10, 2009 at 8:53 PM
