1996 Plymouth Breeze rough idle
1996 PLYMOUTH BREEZE
110,856 MILES • 4 CYL • FWD • AUTOMATIC
DOCTOR DE CARROS
the computer of the car claims that the timing belt is a tooth off but i checked it and everything is fine. all the timing marks match. when the car is idleing it sounds as if the car has a misfire, but when it is accelerated it sounds fine no miss fire or rough acceleration just a rough idle. when the car is running and you come to a stop it dies, and it starts right up again with a rough idle. I have put new spark plugs, timing belt, cam and crankshaft position censor, all to try to get rid of the problem. i checked the compresion and all the cylinders have a 175 psi compresion.
Feb 21, 2008 at 9:57 PM
BMRFIXIT
  • 19,053 POSTS
[quote:de6a7cf71a="Doctor de Carros"]Engine Performance problem
1996 Plymouth Breeze 4 cyl Front Wheel Drive Automatic 110856 miles
the computer of the car claims that the timing belt is a tooth off but i checked it and everything is fine. all the timing marks match. when the car is idleing it sounds as if the car has a misfire, but when it is accelerated it sounds fine no miss fire or rough acceleration just a rough idle. when the car is running and you come to a stop it dies, and it starts right up again with a rough idle. I have put new spark plugs, timing belt, cam and crankshaft position censor, all to try to get rid of the problem. i checked the compresion and all the cylinders have a 175 psi compresion.[/quote:de6a7cf71a]
what is the code
are you sure of the timing marks or you used the old belt marks
Feb 21, 2008 at 10:41 PM
