1996 Plymouth Breeze odometer stuck speedometer doesnt work
1996 PLYMOUTH BREEZE
106,595 MILES • 4 CYL • 2WD • AUTOMATIC
TROTINEL
Hello, I have a 96' Plymouth Breeze 2.0 SOHC, that has 2 problems that occurred at the same time. a problem with odometer - it lights on but is 'stuck' at 106k miles for 2 months now and another is the speedometer -it is death, does not show me the speed. everything else work. I replaced speed sensors input / output nothing happened. (everything started after I parked the car underneath the sprinklers)
I don't know if is a mechanical(wheel sensor) or electrical problem (a shortcut or a loose wire) .
Just before I start the car (first position at the ignition switch -when all the lights came ion an the dashboard ) the speedometer pointer moves up just a little bit and when I turn the car off it cames back to zero.
I appreciate your help
Thank you
Sev
Apr 12, 2008 at 2:01 PM
MERLIN2021
  • 17,250 POSTS
Is the check engine light on? Have it scanned for B codes, either the cluster is no good or the BCM. If all other exterior lights seem ok cluster is most likly the problem, but a scan will show for sure...
Apr 14, 2008 at 1:14 PM
TROTINEL
Well, I tried to have it scanned several times , but the scanner can not connect ( an error ) , the check engine light came on recently, and vent off,.. everything works on the car but the speedometer ( death ) odometer ( stuck at 106K) and the cruise control.
Thank you
Sev
Apr 19, 2008 at 12:09 AM
MERLIN2021
  • 17,250 POSTS
Go to the dealer and have your PCM reflashed there is a tech bulliten on chrysler cars with this problem...you will not be able to pass a state inspection until you do!
Apr 19, 2008 at 6:51 AM
