Hello, I have a 96' Plymouth Breeze 2.0 SOHC, that has 2 problems that occurred at the same time. a problem with odometer - it lights on but is 'stuck' at 106k miles for 2 months now and another is the speedometer -it is death, does not show me the speed. everything else work. I replaced speed sensors input / output nothing happened. (everything started after I parked the car underneath the sprinklers)
I don't know if is a mechanical(wheel sensor) or electrical problem (a shortcut or a loose wire) .
Just before I start the car (first position at the ignition switch -when all the lights came ion an the dashboard ) the speedometer pointer moves up just a little bit and when I turn the car off it cames back to zero.
I appreciate your help
Thank you
Sev
Thank you
Sev
Apr 12, 2008 at 2:01 PM
