Hello –
Thanks for the information back.
I know you had the sensors/codes checked before but have you over the last few days per my request? If not, it is possible that things may have gotten worse to throw a code besides the O2 sensor.
It hasn’t quit on you since your post so you haven’t been able to check for spark or fuel when it quits…….is this correct?
I have attached some information for you for you to review.
To me since it starts when you put a load on it - this is usually the Throttle Position Sensor TPS or Mass Air Flow sensor……but the book says (if applicable) on that one.
The common items between acceleration under load, acceleration and rough idle is your TPS, MAF or your MAP sensor.
What I don’t want to get away from though is your fuel pump. You are driving along…the demand on the pump is at one setting – you demand more and it cannot keep up and slowly drops off and then is hard to restart. Have you had your fuel pressure checked yet?
I would get the O2 sensor changed also……………
I have attached some info for you on the various things you have said. You need test equipment for the checks. If you have a digital volt meter I can provide the checks for the MAP and TPS if you would like.
NO START OR HARD START
• Ensure battery is fully charged.
• Check spark plugs.
• Perform spark test.
• Check for sufficient fuel and fuel contamination.
• Check fuses.
• Ensure ignition timing and fuel pressure are correct.
• Check fuel injectors.
• Check crank and cam sensors (if applicable).
• Ensure timing belt or chain has not jumped.
• Ensure ignition coil resistance is correct.
• Ensure rotor, distributor and plug wires are okay.
• Check ignition control unit (if applicable).
• Check coolant temperature sensor and connector.
• Check TP sensor and connector.
• Check airflow sensor.
• Check anti-theft system (if applicable).
• Check for contaminated fuel.
• Check for vacuum leaks.
• Ensure fuel pressure is correct.
• Check for gasoline in oil.
• Check ignition and sensor wires for proper connection.
STARTS BUT STALLS
• Check fuel pressure.
• Check coolant temperature sensor.
• Check TP sensor and connector (if applicable).
• Check idle air control motor.
HESITATION - ACCELERATION
• Check distributor cap for moisture (if applicable).
• Check minimum idle airflow.
• Ensure spark plug wires are okay.
• Ensure spark plugs are not fouled.
• Check EGR valve operation.
• Check MAP sensor.
• Check ignition and coil circuit.
INSUFFICIENT ENGINE POWER
• Check airflow sensor (if applicable).
• Check for air inlet restriction.
• Check air temperature sensor (if applicable).
• Check for restricted exhaust.
My suggestion – get the codes checked again as I stated above.
Chang the O2 sensor.
Check the TPS and MAP and the fuel pressure.
Jan 18, 2009 at 11:18 PM
