Electrical problem
1962 Plymouth Belvedere V8 Two Wheel Drive Automatic
My temperature gauge has never worked(is always @0 )I think it's a bad sensor on the block. Wire's connected to gauge, new gauge etc. I went to remove it to check it out and coolant started leaking out. The car was cold, not run in 24 hrs.My question is.... How much coolant can I expect to come out, and should I drain the coolant before removing the sensor?
Apr 17, 2010 at 5:38 PM
