1969 Plymouth Barracuda ignition resistor
1969 PLYMOUTH BARRACUDA
JACK1983
  • 6 POSTS
Electrical problem
1969 Plymouth Barracuda V8 Two Wheel Drive Automatic
why am i burning through ignition resistors
Jul 26, 2009 at 3:09 PM
DOCFIXIT
  • 18,828 POSTS
Is ignition stock? you have a four prong double resistor? which is burning out top or bottom?
Jul 26, 2009 at 3:19 PM
JACK1983
  • 6 POSTS
i have a two prong and the whole things is burning up (i was told by advanced auto that the resister was for the ignition had to take the old one in to ask because i didnt know and thats what they told me it was but the location is right in front of of the driver inside the engine compartment
Jul 26, 2009 at 3:22 PM
DOCFIXIT
  • 18,828 POSTS
That is the ignition resistor it drops voltage to coil to @ 8V to keep points from burning up. Is system stock? Have you gone with diffenent coil? electronic dist?
Jul 26, 2009 at 3:27 PM
JACK1983
  • 6 POSTS
knowledge of engine repair is limited i have no idea what you just asked i know the system is similar to what came in the car when it was sold other then that i havent a clue
Jul 26, 2009 at 3:28 PM
DOCFIXIT
  • 18,828 POSTS
O.K. have you had car very long ? or did problem start up soon after purchace? do you have a volt meter? if yes measure voltage to Old School name Ballest resistor in and out. Look at coil does it say ues with external resistor on it? Can you pop dist cap and visually describe what tou see?
Jul 26, 2009 at 3:35 PM
JACK1983
  • 6 POSTS
problems started soon after i purshased the car back in april the problems stared small then slowly progressed to this i ve already preplaced
spark plugs
alternator
battery
possitive batter cable
slowly replacing things wont be able to remove the dist cap till tomorrow and sorry i dont have a volt meter
Jul 26, 2009 at 3:39 PM
DOCFIXIT
  • 18,828 POSTS
With new ballast how long will it run? Does it run well?
Jul 26, 2009 at 3:47 PM
JACK1983
  • 6 POSTS
i dont know the car wont even start because as soon as i try to to i burn right through them
Jul 26, 2009 at 3:53 PM
DOCFIXIT
  • 18,828 POSTS
O.K. there is a direct short in circuit to coil. On coli there is a Neg terminal --- and a positive terminal +. Check wire to positive side is insulation frayed ? remove wire with new ballast try and start if no burning of ballast the coil is faulty internal short.
Jul 26, 2009 at 4:01 PM
JACK1983
  • 6 POSTS
gonna have to break it down barney style for me cause i am confused
Jul 26, 2009 at 4:35 PM
