Rough Idle
PLYMOUTH ACCLAIM
DAN7351
  • 5 POSTS
My car ia a 1991 Plymouth Acclaim. It has a 2.5 non turbo engine with 195000 miles on it. It was idling rough for a while then the camshaft broke. I replaced the camshaft but it still idles rough. It idles rougher when it is in gear. I have replaced wires, plugs,injector,coil. Timing is correct. Can find nothing wrong. Can you help? Thanks. Also, there are no trouble codes on computer.
Apr 20, 2007 at 12:53 PM
JDMHATCH91
  • 13 POSTS
dude, i got the same car as you onlly mine has 107 k on it. try putting gasket sealer between the distributer and the cap.
Apr 21, 2007 at 1:03 PM
DAN7351
  • 5 POSTS
Thanks for your reply. You said put sealant between the distridutor and the cap. Would you explain to me exactly where you mean to put the sealant and what is it supposed to do? Thanks, confused. Please reply
Apr 21, 2007 at 3:50 PM
