1995 Plymouth Acclaim Horn
1995 PLYMOUTH ACCLAIM
65,000 MILES • 4 CYL • 2WD • AUTOMATIC
ML_PICKETT
How do I replace the horn? The fuse and relay are functioning.
Apr 23, 2008 at 10:16 AM
Hi: The horn should be located near the lower side of the radiator. There should be one bolt holding it on. Unbolt it, and remove the wiring. Replace it in the reverse order.
Oct 19, 2008 at 5:59 PM
VIPERTEK
  • 40 POSTS
you can test horns. is air bag light on ? horn runs thru the clockspring .
Jan 9, 2009 at 10:56 AM
