1994 Plymouth Acclaim Lost Power
1994 PLYMOUTH ACCLAIM
124,000 MILES • 4 CYL • 2WD • AUTOMATIC
CENTER
  • 4 POSTS
Driving along and all of a sudden the engen would not power the car . slowed down to 5 mph and that was as fast as the car would go . I put in a new fuel pump and new fuel filter . Checed the throttle body fuel injector and it seems to be pumping . EGR valve moves freely . I can start the car and it will idel , however when giving it gas in park it will hesitate and die out . getting some backfiering , and the Cat is glowing red hot .
have any ideas ?
Dec 3, 2008 at 12:12 AM
BMRFIXIT
  • 19,053 POSTS
check timing
and timing belt
Dec 3, 2008 at 6:47 AM
CENTER
  • 4 POSTS
the timeing is ok . it does jump due to the eradic ideling . is there a way to test the throttle positioning sensor?
Dec 3, 2008 at 9:41 AM
BMRFIXIT
  • 19,053 POSTS
If u think its the TPS you can use a volts meter to check the volts as paddle pressed the volts should go up
and to a wide throttle volts 4.9V
I would suspect MAP sensor before the TPS
disconnect TPS does it start and run (it should )
check timing belt if slipped a notch or so
check dist.and timing
you said that the fuel pump is new
what do u have for fuel pressure ?
Dec 3, 2008 at 1:32 PM
CENTER
  • 4 POSTS
The throttle positioning sensor like you had said during idle and unpluggin made no differance ,. However when probing it I get an on or off . no variation in voltage . and it just spikes at 12 volts then down to zero . then to 12 and back to zero .
Dec 3, 2008 at 11:21 PM
BMRFIXIT
  • 19,053 POSTS
Something is wrong here !! 5 volts should be and no more at idle it should be less then 1volt and as you increases the throttle volts should go up no more then 5 volts are u sure you are testing the TPS and if so you should have a check engine light with a TPS code cycle key on off on off on off on with in 5 sec check engine light blink codes (* ** code 12 ***** ***** code 55 ) and so on check the TPS harness and plug
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_107.jpg
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic2_58.jpg
Dec 4, 2008 at 6:19 AM
CENTER
  • 4 POSTS
Your right the TPS is functioning correctly .
I will double check the timeing .
Dec 4, 2008 at 10:02 AM
BMRFIXIT
  • 19,053 POSTS
all you need for timing belt from picture available to u for free just click below or click timing belt marks on the left
Dec 4, 2008 at 4:18 PM
