1994 Plymouth Acclaim Engine cooling and Head gasket
1994 PLYMOUTH ACCLAIM
43,000 MILES • 4 CYL • FWD • AUTOMATIC
MTHUNDER15
I've got a 94 Ply Acclaim, 43,000 miles. It started to go through big swings in the temperature gauge and then I noticed i was going through a lot of coolant. i checked all the hoses and related systems, and no leaks. Finally the engine started missing badly at idle, and then also on the highway. I pulled the first spark plug and i can see coolant in the cylinder. I did an oil change within the last six weeks and the oil was fine, no coolant in it. I'm thinking head gasket or maybe a cracked block.
Apr 10, 2008 at 6:20 AM
SERVICE WRITER
  • 9,123 POSTS
Sounds like a head gasket. Pull the head and send it to a machine shop for evaluation. That is a pressure test and magna-flux for cracks. If okay have them surface it. I have yet to see a cracked block as it isn't the weak link...although a possibility.
Apr 10, 2008 at 6:25 AM
